cgrums
- Oct 27, 2006
Thanks! Gonna give this a shot tonight.
Originally Posted by tomb /img/forum/go_quote.gif I've just about given up suggesting this, seems like no one else has had this trouble. With me, it happened to every one of my 4 Milletts in some degree or other: check the tube sockets/tube pins. All it may take is a little tube wiggling to get the bias voltage to register. Connect your multimeter up so that you can watch the bias voltage on one of the tubes. Wiggle it and see if the voltage drops below your TREAD's supply voltage (by more than 1 or 2 volts). If so, then slightly bend the pin pairs together that correspond to the bias connection (pin 7? I can't remember). Try to bend them slightly out or to the sides in line with the pin circle. It depends on how the socket is loose. As I said, maybe it was just me, but almost every one of my sockets gave me fits (ceramic PCB). Moreover, if the one near the Pot is loose, the entire second tube won't conduct due to the single-ended design. Thankfully, a slight bending of the pins is all that it takes. Long-term, you might try popping the tops of the socket off and squeezing the socket tabs together slightly with a pair of pliers. If they're glued, you may be able to get an Xacto blade in there to separate the halves. BTW, you might try 27V with the TREAD - that's the standard most use. It was confirmed in Amb's tests, too, as the voltage that gave the best all-around results. That would be 13.5V on the bias for each tube. |
