Very good. You're learning.
I just checked a spare unpopulated board. I checked every apparent ground via against the IG pad and they all connect. It would be interesting to know exactly which pads did not conduct. We all have different revs of the board, of course, and I think they may have been made by different board houses.
The lesson here, of course, is to check continuity when you switch pads or use what looks like a ground via. I have gotten in a habit of buying a spare board, mainly to test continuity of the pads during and after building and cement my understanding of the board layout. For example, if I am doing a pre-power up continuity check on important points in the circuit, the spare acts as a reference so that I know FOR SURE what pads were originially connected before I populated the board. I have older eyes and sometimes I am unsure if a pad is connected to ground plane without a very strong magnifying glass. Even with a glass, I trust my DMM more than my eyes.
I do a lot of checking before I power up a board the first time. I also immediately check important voltages after the first power up, and if possible before the chips are installed. I like to see V+ and V- going to the power pins and NOT see V+ and V- on things like my output L&R pads, opamp In+, things like that.
Regards,
Neil
