Emon
- Dec 28, 2003
I built a Millet Hybrid and a STEPS over a month ago. It worked great. But it was sitting in a cardboard box because I never finished building the chassis. Well, I did that a few weeks ago, and at the same time made all the connections modular so I could mount all the components easier. The biggest change is that I had my Alps RK27 on a small piece of perf board with a 10 pin ribbon cable leading back to the PCB. I checked and checked again, and all the connections were fine.
But when I turned on the amp without a source, a 60-ish Hz hum buzzed loudly in both channels. Maybe more than 60 Hz, sounded like a fluorescant light hum. But when I plugged in my source the sound almost went away, only audible with the pot at the high end (I run it at about 9 o'clock with my E-MU 1212m). I just finished putting it together so I wasn't going to bother with it, especially since it wasn't bothering me much.
So today I decided to figure out what was going wrong...I figured just a simple grounding issue or something. I removed the ribbon cable setup and used some better wire (I think the ribbon cable connector was shoddy), hardwired onto the pins of the pot. Well, the hum was still there. So I fiddled around in my STEPS a little, thinking maybe I accidentally fried my LM317 with static when I was carelessly moving the boards around when putting them into my chassis and modularizing all the connections. I thought maybe it wasn't working right and letting real noisy power into the amp or something. So I replaced it, the hum was still there. Then I accidentally shorted one of the power diodes (one of the set of four in the TO-220 packages) to ground.
Next time I'll put heatshrink over those. I measured the voltage drop on the supposed dead diode and the reading was the same (or close to) the other diodes. I waited a while, plugged in the AC and got arcing under the AC line filter. I'm thinking since I fried one or more of the semiconductor components the AC arced back to ground since it had no where else to go.
So my question is: What could have caused the hum on my Millet Hybrid, and what's dead on my STEPS? I was rather careless when modifying my Millet and STEPS, letting the bottom of the boards slide around my old, almost fuzzy workbench (it's some crappy particle board). So I'm thinking I fried one or more semiconductor components on the Millet, probably the buffers. For the STEPS I probably cooked the LM317 and one or more of the diodes.
Also, could any of the box caps be damaged despite the complete lack of physical evidence? I've seen plenty of electrolytics pop, but never a box or tantalum cap. There's no melting, no soot or scorching under the caps, so I'm thinking they're fine.
So any thoughts? Right now my plan is to replace all the semiconductor parts on both my Millet and my STEPS. Shouldn't be more than 15 dollars I think. Are there any other components that could be dead? I'll also probably go ahead and order some 12FK6 tubes to replace my 12AE6A tubes (which aren't even matched). But I doubt the tubes had anything to do with it.
