gsteinb88
- Jan 16, 2006
So, ive built two Millets, and both have the same problem. I will go into detail about one of them, as they are different.
Configuration:
-Alps Blue Velvet (i havent figured out how to use the ground pad...)
-HA3-5002-5Z Buffers
-Neutrik PCB mounted 1/4" jack
-Neutrik RCA jacks connected via 26ga SPC wire, ground terminals jumpered and then connected to pad
-Unregulated 24v Wallwart (I have a TREAD on the other one, nothing on this one)
-12AE6A or 12FK6 tubes
So in detail, i get a very loud buzzing when i turn the amp on, but that goes away after a few seconds, so im not concerned about that one. However, whenver there is a cable connected to the neutrik RCA jacks, i get this humming in the background like it is picking up EMI or something to the effect. When i have no cables connected, i get basically a black background with a more than tolerable amount of noise. When i try to listen to music the humming is completely intolerable, and ruins the music. I can hear the music behind it though.
Any help would be appreciated, thank you.
-g
EDIT: I should add that while i get EMI hum with wires on only the millet, when it gets plugged into a source, the hum gets much louder, and becomes a ground loop hum, i think. I have a hammond metal enclosure with plastic endplates. Any idea where the ground loop could be coming from?
Configuration:
-g
