rgmffn
- Jul 15, 2015
Thank you for the feedback. Actually I might also opt for the Valhalla 2. I am sitting a distance from the amp and really wish there was a remote control for volume control.
If you are ok with running a cable over to your seating area, I use the Emotiva Control Freak to control the volume. If you happen to be in a corner, you can route it along the baseboard out of the way. You'll likely need some patch cords to extend its reach. It really works well. I didn't detect any degradation in sound using it.
Most likely you'll need to get the Unbalanced model (with RCA ends) as opposed to Balanced (3 prong connectors). So, make sure you order the right one.
I see that Emotiva themselves are out of stock of the Unbalanced, but it's my understanding that they'll be back in soon. I did find some Unbalanced ones in stock here though.
HTH..
