potatoos
- Feb 9, 2011
I would like to be able to use my Etymotic HF3 with my PC (Windows 7), but that would require a splitter of some sort to separate the audio in and the mic outputs that are on the single plug of the HF3 (3 ring, smartphone 3.5mm connector, whatever it is called). The problem that I am seeing with the run-of-the-mill splitters on Amazon is that they don't work with the HF3 because it has more than one button. It has separate buttons for volume up, volume down, and a pause/start/answer phone button. If there is a simple fix, I would certainly be appreciative.
