Coroner
- Jan 26, 2002
I built a Meta42 a while ago using 2xAD845 ICs running on 2 x 9V batteries (about 4 hours juice then dead). So I recently built a dual rail +-15V power supply. I connected removed the TLE2426 and the EL2001 in the Meta power supply. I then connected 0V from my PS to the ground on the Meta board and the +/- 15V to where the batteries were attached - identical to my battery setup. The voltages comming out of my PS are -14.26 and + 14.34 so well within the acceptable voltage range of my ICs. When I applied power the +/- Pins of the ICs also read +/-14V, so I inserted the ICs and applied power checking components for temperature - the AD845s started to get quite hot after about a minute - the EL2001 stayed cool. I removed power and triple checked all connections - no errors I could see. So I applied power again and attached an audio source - adjusted volume all the way up and no sound - no noise at all actually - complete silence. So I disconnected power and noticed the AD845 had gotten quite hot again. So I reconnected the TLE2426 EL2001 and the batteries and tested - no sound/noise only silence. I then replaced the AD845s with an AD823 which was known to be working - no sound still. I checked all the voltages again - all correct. I haven't been able to test the buffers as I don't have any spare ones.
I have triple checked the board for solder bridges and wiring mistakes - it worked flawlessly before on the original dual 9V setup but now it does not do anything at all. I am presuming the OP AMPs are ok as replacing them has made no difference. Maybe it is the buffers? But I have no way of replacing them.
Is +/-15V too much voltage? I checked the spec sheets and it should be fine.
I am quite annoyed as it seems I may have fried quite a few $$$ worth of ICs.
Any ideas?
The power supply checks out perfectly - although I don't have access to a CRO to check for oscillation - the enclosure is wooden so I have not connected mains earth to 0V which I presumed would eliminate 50Hz AC hum.
HELP
Any ideas?
HELP
