Melodious MX-U8 USB Interface 8 Core XMOS chip
Aug 19, 2015 at 1:10 PM Post #274 of 658
Any link - possibly ebay?  All I'm finding for 5V are 500mAh
Thanks
Sorry, my mistake, i sue Lithium Ion USB powerpack, it's the easiest way and sounds very good.
Lithium Polymer has lower internal resistance, but you have to use several in parallel to get the needed amperage and internal resistance
Aug 19, 2015 at 1:37 PM Post #278 of 658
Oh thanks - yes I found this one - just need to devise a cable from USB to dc socket for input
http://www.ebay.com/itm/XIAOMI-16000mAh-External-Power-Bank-Li-ion-Battery-Charger-5V-3-6A-100-Genuine-/131545309954?has
Aug 20, 2015 at 9:47 AM Post #281 of 658
Hydra Z on the way!
I bought a 16,000 mAh Li ion battery to power the unit -should have plenty of juice and are very cheap (and can always use to back up my phone), if the sound pans out, I will but another and have one always on the charge.
Capacity 16000mAh
Color: Silver
Battery Type: 18650
Input: 5V 2A
Output: 5V 2.1A*2  MAX 3.6A
I will get a cable to connect the power from the battery and will also try this Forza FAW Copper Series split cable I just received.  Seperate data and power USB leads.
http://forzaaudioworks.com/en/product.php?id_product=46
Now I'll be able to do a head to head shootout with the Gustard U12 (upgraded caps), Melodious MX-U8 (upgraded caps), Audio Breeze (upgraded caps), Hydra Z with wall wart or Li ion power.  Fun!!
Aug 20, 2015 at 7:33 PM Post #282 of 658
Can't play 24 bit 192 Khz with MX-U8. It comes out statical, very quiet with mainly static noise from the right side only. All frequencies below 192 play perfectly. I think there's something wrong with the converter itself because I get the same result with two separate dacs and when I go into the dac with a usb input, using the same usb cord, it works fine. Can someone confirm I haven't made an error in my troubleshooting before I send back the Melodious?
Aug 20, 2015 at 10:13 PM Post #283 of 658
Sounds like it's a bad unit.  You did the right diagnosis routine.
Aug 23, 2015 at 1:56 AM Post #285 of 658
I would try a different playback software also and use the MX-U8 original drivers...
I am not an expert, but I would think possible to have some type of driver conflict if you have 2 DAC drivers and the MX-U8 driver all active on the same computer...
