hawaii2000
- Feb 19, 2006
I just bought a Micro Amp and had been wondering at what volume I should set my iPod for optimal audio quality. I might have overlooked it, but I didn't see this information in HeadRoom's documentation or website. Suffice to say, then, this thread has been very helpful.
Mahalo.
Originally Posted by NotJeffBuckley Edit to be more helpful: I find that running a source from a relatively low output setting (say, 60% of its possible output) can go a long way to correct channel imbalances, op-amp clipping/distortion, etc. from the source. So, run it relatively low into your amplifier then use the amplifier to bring that signal up to volume. You'll generally end up with the best possible sound quality this way, because you're not pushing the source's (usually weak) power output section too hard and clipping. |
Mahalo.
