vlb
- Mar 1, 2009
Hi
I have an Audio research D250, its a wonderfull amp even though it eats a fortune of tubes and produce to much heat to be used in the summer.
I have changed all the tubes and have done all the adjustments except "Ac balance" and now I need your help.
The manual says I should measure thd or thd+noise when driving a 16ohm load with 10W @1khz and then adjust it for >0.005% THD or 0.02% THD+Noise.
I have 4x 4ohm 5W resistors to get the 16ohm load, and I can generate a 1khz signal with my dac, But what kind of intrument do I need to measurre thd or thd+N?
Thanks
Thanks
