Hi Crgreen. My understanding is that the tubes themselves are the source of microphonic vibrations. Maybe some others can chime in?I appreciate all of that, but my original question remains: when listening on headphones what is the source of the microphonic vibrations?
McIntosh MHA200 Impressions
- Thread starter warrenpchi
ABQ2
I too listen right at the source, not at the computer. I have the Mullards and listen to vinyl with an MC cartridge with the Mac MP100 preamp and the the MHA200. Focal Utopia phones. After paying special attention to phono cable routing and connections I have very black background and fantastic sound. Volume control on the subject amp is a pain but well worth it for the result. I have vinyl from the sixties that sound brand new.This is great info Jason, very nice of you to provide it.
In case you have some kind of influence I'd like to share a need! Now that this market is growing, I really hope headphone amp designers will start to consider that not all their customers use these at a work desk sitting in and office chair. A lot of us have this type of amp installed in their living room and relax on a sofa a few feet away from the equipment. For this type of use, a remote control for volume adjustment is crucial and again a lot of us want a headphone amp that is similar in functions to an stereo integrated, not have to control the volume with the source/DAC.
Thanks a lot and please continue sharing future development, we love it!
I just received my Mullard CV4024's. Agree with Jason - more aggressive dynamics by a tad. Sounds great though. Jason, or others, what other differences besides dynamics do you hear when you compare the Mullards to the stock JJ tubes?Mullards make the MHA200 a tad more aggressive. Assertive in dynamics
Yesthereisgasinthecar
Since you invited ; in this scenario, I would lean towards snake oil. At least, you'd need many double blind tests to remove the placebo effect and get a legitimate before and after consensus of sound quality improvement. Given that tube manufacturers and users of tubes, from an OEM standpoint, want to put their products in the best light possible, you would think that they would bring such dampers 'in house' to take advantage of their benefits if they did in fact exist. The fact that they remain aftermarket probably tells us all that we need to know.Hi Crgreen. My understanding is that the tubes themselves are the source of microphonic vibrations. Maybe some others can chime in?
Crgreen
- Apr 22, 2016
Audio Research do provide dampers, two for each of the smaller tubes, with their products.Since you invited ; in this scenario, I would lean towards snake oil. At least, you'd need many double blind tests to remove the placebo effect and get a legitimate before and after consensus of sound quality improvement. Given that tube manufacturers and users of tubes, from an OEM standpoint, want to put their products in the best light possible, you would think that they would bring such dampers 'in house' to take advantage of their benefits if they did in fact exist. The fact that they remain aftermarket probably tells us all that we need to know.
I suppose my point was that although tubes are known to be microphonic (something exploited by certain guitarists) my understanding was that the cause of the vibrations is external sound waves, such as from speakers (which won’t play a part in headphone listening) not the tubes themselves. I accept however, that some suggest nearby transformers can generate vibrations picked up by tubes.
Regarding tube ruggedness (aka its ability to resist microphonics and vibrations), one might want to pay attention to whether the tubes are designated military spec (for example vacuum tubes used in aviation or in naval applications). Another sign of ruggedness is the use of triple mica spacers, being more stable than tubes with double mica. One will encounter these terms questing for decent vintage 12AT7 tubes for the MHA200
valphil7780
I purchased an Alpha-Core Goertz TQ2 cable to connect my BlueSound 2021 with the MHA200. Is it a good choice ? This allows me to connect it balanced from RCA (BlueSound) to double XLR (MHA200)
Why would you make it complicated? From RCA go to RCA, from XLR go to XLR.I purchased an Alpha-Core Goertz TQ2 cable to connect my BlueSound 2021 with the MHA200. Is it a good choice ? This allows me to connect it balanced from RCA (BlueSound) to double XLR (MHA200)
However, if you have invested already in a silver interconnect cable and you like it, just use it.
The MHA200 is internally single ended, so there must be something inside that transforms the XLR to SE before the amplification. I do not remember if it was particularly discussed here. Usually it is a small transformer. When it is implemented properly it shall not affect the sound too much.
valphil7780
I therefore committed a stupidity by buying cable ... I thought that it would make it possible to use the balanced inputs of the mha. the bluesound does not have an xlr outputWhy would you make it complicated? From RCA go to RCA, from XLR go to XLR.
Deleeh
You can easily use a cable from XLR to Rca - there is nothing wrong with that.
I did this on my Dac as it only has one RCA output and the XLR was free.
What I can't say is whether 4 volts then arrive at the Mcintosh instead of 2 volts.
At best, it is regulated down.
valphil7780
thank you for the information. what equipment do you have to power the mha200?You can easily use a cable from XLR to Rca - there is nothing wrong with that.
valphil7780
Otherwise for the cable I had a 2 RCA / 2 RCA AudioQuest Big Sur but I preferred to change to the balanced Goertzthank you for the information. what equipment do you have to power the mha200?
ochre korg
So now I have replaced the original 12AT7 tubes for Gold Lion Ecc81 tubes, and the first hour playing sounds great, only on the V3 position I notice on the top on the left side the “orange dot” or little light shines weakly, and on the right side no light at all, is this a bad thing? Does it matter? Or is this ok?
A picture would help to decide what sort of orange dot you have. Red plating was discussed around here:So now I have replaced the original 12AT7 tubes for Gold Lion Ecc81 tubes, and the first hour playing sounds great, only on the V3 position I notice on the top on the left side the “orange dot” or little light shines weakly, and on the right side no light at all, is this a bad thing? Does it matter? Or is this ok?
https://www.head-fi.org/threads/mcintosh-mha200-impressions.957625/post-16719317
Is it similar to the one on the tube on V4 position?
ochre korg
