jrussell6
- Feb 26, 2006
Hey folks, so here's the skinny, when i first bought the total bithead, i plugged the usb into the the first of 3 usb ports on my 17mbp, i got a bunch of noise and hiss and crackle, so i tried the next one down the line and it was crystal clear,, so i concluded that the first usb port was too close to the power supply/magnetic power cord, then a few nights ago, i went to listen and the 2nd usb port was doing the same thing, alot of noise, and when i turn the volume down in itunes, it really acts up....
so i've switched to my last usb port which is on the other side of the comp, and it sounds fine usually, but occationally sounds like you were tickling the connection with a feather, but what the heck, is this a symptom of something else?? should i be worried about my comp?
i've been planning on moveing up to a micro stack, so i imagine all problems would go away when i switch to optical cabling, but what's going on here? does anybody share this experience or have any guesses?
