First of all: I have no idea whether I've placed it in the right forum, I'm sorry if I've placed it in the wrong forum.
Like the title suggests, I'm trying to maximize my audio quality on a low budget, which is €150,-. But I have no idea what would give me the most bang for the buck (actually, I don't know much about audio setups in general at this moment). I'm thinking of buying the speakers at last, since it's likely that I won't use them a lot (basically only if there's no-one but me home). I will use it for music (hardcore/hardstyle, metal, classical), anime and some occasional gaming. They don't need to be portable, since it's going to be used at roughly the same spot all the time and space isn't an issue either.
Right now I'm using the Superlux HD 681 with my motherboard's onboard soundcard (Realtek ALC892). So the smartest move would be to switch to something else that's not the onboard chip right?
What would you guys recommend?
