Originally Posted by NeilR
dsavitsk,
You and I had a discussion here, where I think we came to the conclusion that 75-100uF was needed for a corner frequency of about 2HZ.
Hmmm. I don't think I did the math there, or else I messed it up one of the times I did do it. Just to make sure this is correct, I'll show my work this time.
First, to calculate the impedence the cap sees, it is 2K5 (Rk) in parallel with
(RL + ra) / (mu + 1)
RL is the plate load, ra is the plate resistance of the tube, mu for these tubes is somewhere between 5 and 20 depending upon the tube chosen. ra is something I don't know, but larger than 1 (probably larger than 1000.) RL is big -- for convenience we'll call it infinite, but it is certainly larger than 1M (the bottlehead kit is about 3M for those interested.)
Anyway, 2K5 in parallel with anything large is going to be close to 2K5. Moreover, since 2K5 is an estimate, and in reality it is closer to 5K, this is a fine fudge.
So, using the cap equation, with a 47uF cap, you have
F = 1 / (2 * pi * .000047 * 2500)
which is a corner frequency of 1.35Hz. This is very low.
If it were me, and I were ordering from partsconnexion, I might try the 47uF os-cons. Mind you, I've not tried them, but I have heard from people who think they are very good for cathode bypass. Otherwise, there are a ton of different blackgates. Also, check out the elna selection at handmade.
-d
