NeilR
- Dec 2, 2005
dsavitsk,
Thanks.... I was curious why you suggest that power caps make more of a difference in solid state amps than tube amps (technical reason?).
Edit: or maybe I am confused over quantity vs quality....
Regards,
Neil
Regards,
Neil
Originally Posted by dsavitsk It depends a little on what best is to you. Blackgate Std are very good caps. They are clear and crisp, but maybe just a tad thin on the bass -- what sonme like to call neutral. Cerafines are sort of Std lite in that they have a similar sound signature, but are not quite as good. Welborne says he thinks they are 98% as good, and I think he is probably about right. On the other hand, BG N series, K series, and FK will be a bit warmer and fuller. Nichicon Muse ES series are very warm and bass heavy -- euphonic, but not as detailed. I am actually a big fan of the ES's, but you have to be careful as they are easy to over do. Muse KZ are less warm, still bass heavy, more detailed than ES (though less than BG) and to my ear can sound a little hard on the top. How any of these will influence the particular amp is hard to know, and i think any of them are fine. I used BG Std's in one Millett and it sounds slightly better to me that the one I used Muse KZ's and cerafines in. So, I'd pick caps from one vendor for the whole project and you should do fine. All elna, or all Muse or all BG will be fine in any case. |
