glezba
- Jan 9, 2013
Dear friends, I need a pair of speakers for my amp. I know it can sound a little weird, but I need them to be in red color. So the choice should be between these two:
HECO MUSIC COLORS 100
[size=11.818181991577148px]http://www.redcoon.es/B296545-Heco-Musi ... ter%C3%ADa[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Specs:[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Principle 2 way design bookshelf speaker, [/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]bass reflex[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Equipment 4.5“ woofer-midrange[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]1” dome-tweeter[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Power handling (RMS/max.) 70 / 120 watts[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Impedance 4 - 8 ohms[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Frequency response 38 - 35,000 Hz[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Crossover frequencies 2800 Hz[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Recommended Amplifier Output 20 - 120 watts[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]Sensitivity 89 dB[/size][size=11.818181991577148px][/size]
PRO-JECT SPEAKER BOX 5[size=11.818181991577148px][/size]
[size=11.818181991577148px]http://www.audioaffair.co.uk/Pro-Ject-S ... oduct_4816[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]- Bass-refex principle[/size]
[size=11.818181991577148px]- 25mm silk-dome tweeter[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]- 130mm bass-mid driver[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]- 55Hz-20kHz frequency response[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]- 8 ohm impedance[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]- 86dB efficiency (1W/1m)[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]- 10W-150W suggested amplifier power[/size][size=11.818181991577148px][/size]
[size=11.818181991577148px]These are the specs from the amp:[/size]
[tr] [td] Power output:[/td] [td] 35 watts (into 8 Ohms)[/td] [/tr] [tr] [td] Frequency response:[/td] [td] (-3dB) 5Hz - 50kHz[/td] [/tr] [tr] [td] S/N ratio (ref 1w):[/td] [td] >82dB (unweighted)[/td] [/tr] [tr] [td] THD (unweighted):[/td] [td] <0.01% @ 1kHz, 80% of rated power
< 0.15% 20Hz - 20kHx, 80% of rated power[/td] [/tr] [tr] [td] Max. power consumption:[/td] [td] 260 Watts[/td] [/tr] [tr] [td] Input impedance:[/td] [td] 47k ohms[/td] [/tr] [tr] [td] Power amp damping factor:[/td] [td] >50[/td] [/tr] [tr] [td] Bass/Treble controls:[/td] [td] Shelving, ultimate boost/cut
+/- 10dB @ 100Hz and 10kHz[/td] [/tr] [tr] [td] Dimensions (W x H x D):[/td] [td] 76 x 430 x 340mm[/td] [/tr] [tr] [td] Weight:[/td] [td] 5.6kg (12.3lbs)[/td] [/tr]
Thanks in advance for your help.
