intlplby
- Jun 13, 2004
exactly how much of an impact does making a PPA class A impact the battery life of the amp when used portably?
Originally Posted by intlplby exactly how much of an impact does making a PPA class A impact the battery life of the amp when used portably? |
Originally Posted by tangent If you're referring to the op-amp biasing, then how much impact it has depends on how you adjust R9. You can go anywhere from very low current up to high current, over a good 10:1 range, around a few mA. |
Originally Posted by intlplby lets say my load was 32ohms so i would need a high bias of like 22mA |
Is there a rule of thumb how much opamp bias is reasonable |
Has biasing the opamp any impact on the buffers |
My problem is the Zener Diode for my LED cuts out after about 3 hours, but the amp is still going strong. |
On PPA v2 I'll probably jumper across the bias trim pots and safe the 5 bucks |
Originally Posted by tangent I can see that the docs weren't clear enough on picking the zener value, then. I've rewritten that section to be clearer. |
What do you think about running the ground channel at a lower bias than Left and Right? |
12 aaa 700mah cells, 1ma on each channel, gave me 8 Hours of amp time. I've got the opa627s and started to get a little white noise at the 8 hour mark. |
