FallenAngel
Hey guys,
I was curious into the Heed CanAmp in the way it uses a single NPN transistor (BD139-16) as a voltage follower as the buffer to an opamp, so I decided to make a much nicer amp but include this buffer.
I have a dual regulated power supply (very similar to 2 of Tangent's TREADs) which to power this thing.
The amp circuit is the same opamp amplifier circuit used by the Pimeta/PPAv2 (implements Jung's multi-loop topology, without CCS on the opamp).
The buffer circuit is a BD139-16 voltage follower biased into Class-A using a 100 Ohm / 5 Watt resistor with a 220 Ohm resistor on output (in the feedback loop of the opamp through a 10K resistor).
The schematic looks like this:
I'm getting an output DC of 600mV which drops to 500mV over 10 seconds or so, but hangs around there afterwards.
Any idea on why this is happening, why the Heed CanAmp uses this buffer without DC offset and what can do to fix it?
Thanks!
Thanks!
