Davesrose
- Oct 20, 2006
YEP!!!
Another reason why I like sorenson.....Apple's implementation of MPEG-4 sucks compared to it. Microsofts is actually better IMO....as a side note, if you were to make an Apple MPEG-4 and compared it to a Windows MPEG-4, the Apple one would be much larger and not much better quality wise.
There are several ways to get better compression. The easiest is to get a dedicated program that compresses video (like Autodesk's Media Cleaner). But those cost money. You could resize the video, try different interlacing techniques (some aren't that bad really), but the first thing to do would be to mess with your compression settings. I have limited experience with iMovie, so I couldn't tell you about the controls. But somewhere it must let you adjust the video settings for the codec. Just render out a few in different settings and see what it does!
Originally Posted by AuroraProject /img/forum/go_quote.gif Hey, Sorenson 3 looks better than MPEG-4 and it takes up less space! The original H.264 file is 1.2gb, MPEG-4 is 300mb, Sorenson 3 is 200mb! Can I keep this quality level and get the file any smaller? |
YEP!!!
