Mar 6, 2013 at 3:54 PM Thread Starter Post #1 of 2
ksimm033
Im using the stock round tips (Med). They fit well and comfortable, but when in the gym, while running, the music can sound almost a little muffled at times. I run about 4 miles in 30 minutes, so I sweat pretty good. When I'm done and start to lift, it's hard to keep a good seal and I keep having to adjust them to get the best sound. I've tried drying my ears off and the IEMs, then resetting them but that does not seem to help too much. Prior to working out the seal and fit are great. Any suggestions? Should I try the flange tips; will they stay better? Anyone had these issues before?
On a side note, I'm quite impressed with the sound for their price. Clarity is almost to good for a gym IEM if that makes sense. The bass seems deep and fairly tight. Okay sound stage with some instrument separation. For some reason I wish they sounded a little more bassy (for the gym), but maybe after a few more runs I'll adapt to their sound signature. Overall, once I get the fit going, I'll be very happy.
