jerb
- Jan 2, 2005
I'm sure this amp is way past its prime but I remembered that I had a board populated and decided to dust it off and se if I could get it to work.
Now, I'm going through amb's site step by step. The board is fully populated and after a once over I found no solder bridges.
Now for step 6 when I check the voltage across the pins I'm not getting half my supply voltage, I'm getting all of it, a full 24 V.
What could be causing this?
