Is the magnet included with the W4 or should it be purchased separately?Magnetic
Luxury & Precision (LP) W4, Successor to Their Popular W1/W2 USB Dongle is Here!
- Thread starter bluestorm1992
Is included with the blue case that you have to buy separately.Is the magnet included with the W4 or should it be purchased separately?
I was planning to buy the case anyway so that's great to know. ThanksIs included with the blue case that you have to buy separately.
Just Kidding
i just update the lasted firmware. thank you very muchBeautiful photo and cable. I have it and is very well made and flexible. That metallic plate should go inside the case, so it is not visible.I wish they made green case for it also just like the W2.
Are you on the latest firmware? Now all problems are solved with gen2 snapgradon phone
Just Kidding
in the case of W4 LP have sent to our 1 piece of magnet and the case also haveHow did you attach it to the phone? Adhesive?
How is the power output of W4 compared to W2 ? As W4 is weaker on the single end side.in the case of W4 LP have sent to our 1 piece of magnet and the case also have
Just Kidding
a little bit weaker than W2 ACG on single ended. For example, im using Shure 846 on w2 acg ( low gain/ volume 65) / w4 ( low gain/ volume 72)How is the power output of W4 compared to W2 ? As W4 is weaker on the single end side.
Thanks , I thought that may be the case but not too bad. Is it easy to use the volume/dial knob and is the menu exactly as on W2, or there are extra features?
Just Kidding
quality of the case is good. ALPS volume give me good feeling so smooth.Thanks , I thought that may be the case but not too bad. Is it easy to use the volume/dial knob and is the menu exactly as on W2, or there are extra features?
Now they added to the W4 the possibility to flip the screen 180 degrees, that could be useful to some, and the ALPS knob used has a very long life so no worries there.
I have to say, for the IEMs I have that suit warmer sources like Elysian Gaea, FatFreq Grand Maestro or IER-Z1R, W4 sounds amazing.
Especially the Elysian Gaea. It really shines on W4
crazyhank
Do you think W4 is as good as a flagship DAP? Or comes close to SP3000 or Cayin N8ii? Thank you!
Just Kidding
In my opinion, i dont think so. Yes w4 is good. But if you compare with Flag ship tier DAP.... not fair for W4 . It better than Mid range DAP. For example, i have test with fiio m11 plus, hiby r6 pro and shanling M7. P/p w4 is better than that all and w4 is so convenient for traveling or go to the coffe shopDo you think W4 is as good as a flagship DAP? Or comes close to SP3000 or Cayin N8ii? Thank you!
Total: 6 (members: 2, guests: 4)
