Luxsin X9 Desktop DAC & Headphone Amplifier Officially Released !
May 25, 2025 at 8:11 PM Post #91 of 231
Added 4x stick on rubber feet to increase the clearance by 1cm, much better now 😎
I've been running all outputs in Bypass mode for a full day now just to see what the feeling is like without any EQ or effects enabled. As much as I like HP-EQ and some of the filter/effect options, I think on my specific headphones and speakers that a untouched signal from the source just sounds the most natural by just letting both speakers and headphones output how they work best with a given sound. HP-EQ makes the Arya's sound more bassy with an increase in the mids depending on the profile selected, but with bypass it just feels more natural even if it lacks some of the subtleties of HP-EQ.
Further experimentation to be done. My original verdict still stands, but the more I listen in Bypass mode, the more I prefer it for keeping things true to the source and just letting the speakers/headphones make the music more fun, as far as my personal tastes go.
May 26, 2025 at 2:22 AM Post #92 of 231
@Luxsin, any plans to make the X9 available in Japan?
We will be selling in Japan, but the certification process for electronic products there takes quite a long time to complete
Luxsin Audio Stay updated on Luxsin Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/profile.php?id=61564989246242 https://x.com/Luxsin_audio https://www.instagram.com/luxsinaudio/ https://luxsinaudio.com/ https://www.youtube.com/@LuxsinAudio support@luxsinaudio.com
May 26, 2025 at 2:40 AM Post #93 of 231
Thanks!
@Luxsin could I make a feature request? When turning off the LCD display only, for example when I am watching something and want no distractions at all, the volume dial LED pulses, normally this is fine as it's subtle but there should be an option to tell it to not pulse at all if you don't want it for a completely clean look 👍
Also on the graphical EQ visualisation the format and sample rate doe not show up top whereas the other meters show it.
Thanks for the suggestion, we will look into these two requests.
May 26, 2025 at 8:36 AM Post #94 of 231
I agree with you on some points...👍
NOMAX
PS.more on the weekend when I will give my final verdict on the Luxsin✌️
May 26, 2025 at 9:07 AM Post #96 of 231
Fingerprints!
Of course.... with over 30 headphones that I have at home and which i have tried on the Luxsin 🤣
NOMAX
PS.but only the ones where I raise my thumb are in my private collection/signature 😉
May 27, 2025 at 5:23 AM Post #98 of 231
Competition to Lotoo or just a snack in between?
Are you at the HeadFi Meetup at TU Wien?
Unfortunately I can't join because I'm in Linz this weekend
Sorry but I'm already at the lake at this time 😎
NOMAX
PS.where I spend always the summer months
(I'm really thinking about what I should take with me from all my toys🙈....because I can't do without music either😆)
May 27, 2025 at 7:42 AM Post #99 of 231
From your preferred lake to Vienna it's not that far away.
If necessary, you could swim down the Danube or take a canoe. Back by Danube boat.
:yum::upside_down:😊
May 29, 2025 at 5:50 AM Post #102 of 231
Any comparison with D&A Alpha pro?
May 29, 2025 at 11:11 AM Post #103 of 231
I installed the Luxsin USB driver today (it's actually the Eversolo driver) and noticed the default sample rate is 44.1K at 32Bit whereas before the driver it was 48K 32bit. Is this right for others with this (or an Eversolo DAC) installed? I've also just done a Windows Update which installed a feature update so don't know if that had changed anything too.
For all these years I've been using the default a DAC chooses, which has always been 32bit 48K or 24bit 48K.
Might be one for @Luxsin to answer too on what's the recommended here.
