My ATK-CK10 has an incredably low volume. they used to be to sensitive, sometimes the volume could not go low enough. This has now changed and the volume is low on both sides. Im thinking this has to be the the cable or the plug. Not sure if i am able to change the cable with out completely ruining the housing.
Any hints on what cable that should fit, and if there are some magic tricks to make cable replacement more smooth? Once i get home il get at it with twezers and a soldering bolt and see were that leads me.
