Soul_Est
- Nov 23, 2009
I'll give you that one on the economics but I tend go without upgrades (not add-ons) to the core system for a long time (only just replaced the memory in my 3 year old MacBook bumping it to 3GB). The ION would be for playback of h.264 encoded 720p or 1080p video and possibly for use with MythTV later on. I tend not to go with pre-built systems as I never could get what I really wanted (but that may change).
Sounds very good and the extra display (I hope to run a 1080p capable monitor off of it) will definitely come in handy for the multimedia work I plan to do in the near future. Portability would be excellent.
How good is the system at playing back high definition video using PureVideo or VDPAU? Have you tried doing audio production work on it? How's the heat dissipation and battery life? I'm curious about this system outside of the reviews I've read before.
Originally Posted by oohms /img/forum/go_quote.gif Saving money on power bills by spending it on a new computer is kinda a false economy. That said, its pretty easy to build a cheap low power pc - If you don't game or do a lot of CAD/real time 3d rendering it doesn't matter what graphics you have. - SSD's are useless for slow pcs like atoms If you are travelling, consider an eee box + upgrade the hard drive to something bigger, otherwise i would get any atom board, a pci sound card (since it looks like you want to use it for music), a 2TB hard drive and a cheap case for it all. |
Originally Posted by J.Pocalypse /img/forum/go_quote.gif Spec wise, it's sounds a lot like my Asus Eee PC 1201N. At half the price of your build. A good 4GB RAM upgrade is going to cost me $80. I already own a 1TB HDD.. Done. |
