noveltone
- Dec 30, 2007
Great! Thanks for drafting this out.
Thanks for posting aos's design with additional notes. I'd like to ask something. I had bought previously the parts required for Tangent/Hadron's circuit, and he's listing resistor values in excess of 100k. Since I was going to use that circuit I'm resulting in R1 and R4 values of 470k and 511k (if R2 is 100k). Pretty high values and I'm concerned these will introduce needless noise to the Pimeta's power supply. Aside from more current draw, is there any reason I can't tone those down to values more like those shown in aos'?
Collin
You pretty much need to design a circuit board for that, though. You also have to order the chip from the supplier. While you could just hack the analog circuit as well as buy parts in your local electronics store. And it is probably cheaper, too. I agree though, if I was designing something I'd probably use the chip like you mentioned. But if you are building somebody else's design it's much easier to add a small perfboard with a simple analog circuit than open Eagle, spend an hour in it and then wait 3 weeks for the boards to arrive (at high cost)...
