PurpleAngel
Formerly known as Tacoboy
After listening to this amp for about a week plus, I have a few question I was hoping you all could help me with. My typical configuration is to use TIDAL on my pc as a source, plugged into the E10K, with the line out to the line in of the Bravo Ocean, and listening through DT990 250 ohm cans. Usually I have the volume on the PC turned to max, and the volume on the ocean at near 0. After listening for several hours a day, on day 3 I think I was experiencing some ear fatigue. I've never experienced that with the E10K alone. Could the sound out of this amp be irritating my ears? Then today, I decided to turn the volume down on the PC to about 6, so I would have a bit more control with the volume on the Ocean. Turning the volume down on the PC and up to about 25% on the Ocean seems to sound better and different somehow, but I couldn't put into words how. The other odd thing is that using the Ocean, it seems like I need to keep the volume much lower than when not using it. It's as if there is just more sound coming out of the Ocean. Not louder sound, just more of it. It's difficult to describe, but I'm hoping someone will be able to give me some insight into whats going on here. So here are my questions:
Can I cause distortion through the Bravo Ocean if my PC volume is at 100%?
How likely is it that this amp, headphone combination is causing me some fatigue?
Would a different tube help? (can't get new cans just yet)
Does it make sense that the Bravo Ocean is putting out more sound than another output device when set at the same listening volume?
If your ears do better with the PC's volume level set to 60%, cool.
Could be the Bravo just drives the DT990 better when the Bravo outputs more voltage?
