aviphysics
- Feb 9, 2016
Looking for a second pair of headphones to keep at work.
I have been using a pair of Sony V6 since 1995 and they are even better after I replaced the earpads with the Beyerdynamics DT250 Velour pads. I really like these headphones and find them comfortable enough to wear for hours. Sometimes more than 8 hours a day.
My first inclination is to get a set of 7506 headphones and another set of velour earpads, but it seemed worth checking if there was a better option these days. It looks like I can get the 7506 + pads for about $85 and I am not willing to spend too much more than that.
At work I mainly listen to baroque and other instrumental classical, mainly just to block out distractions.
Thoughts on the V6
1) The V6 I find very comfortable
2) I find their audio sometimes accurate to the point of being unforgiving (which can be good and bad)
3) They don't have a lot of noise bleed (which is important for my work environment)
4) They are very durable.
5) I have a pretty large head (like I basically can't wear standard baseball caps) and on occasion have found that some headsets don't properly adjust to it.
Any thoughts on what else would be worth considering?
Thoughts on the V6
