ryan2196
- May 7, 2013
Check you my review for DT1350. It's on my signature.
Which would you reccomend more for metal music?
For metal, amperiors.
Oh ok. Is the headband adjustable on the amperiors?
What do you mean adjustable? Like DT1350? Yes, they are.
I mean like can you make them tighter on your head. It looks like on a lot of pictures the headband isn't touching the heads of people.
Of course they are adjustable. Unless you have a really tiny head, I won't worry about it.
One final question: are they worth 217?
IMO, yes. It fits your needs perfectly.
Alright I'm gonnna go ahead and buy them. Thanks for all of the help!
No problem. Hope you like them.
i will be taking these to high
http://www.louisvuittonend.com/">www.louisvuittonend.com
school. Durability is important, but should be good on
both because they are both made of metal.
I just bought the amperior!
Great! Tell me how you like it.
