Looking for help from computer gurus...
Dec 6, 2004 at 10:33 PM Post #16 of 18
Check under Views -> Current View as Bill Ward suggested, but look under 'Customize Current View'. Check to see if there is anything wierd under 'Group By', 'Sort', or 'Filter'. Set them to [None, Recieved, Off] respectively to be sure that they are not messing it up. You can also try recreating your local outlook profile. Let me know if you need a walkthrough on how to do that.
Dec 6, 2004 at 10:50 PM Post #17 of 18
Originally Posted by Alexhud
Check Norton in the quarantine box and make sure your whole inbox is not quarantined. One time I had a virus in an email and Norton quarantined the whole inbox and all the messages disappeared much like what happened to you.
Good luck
Zero quarantined items... Thanks anyway!
Dec 6, 2004 at 11:22 PM Post #18 of 18
I checked, everything looks like being OK...
Huh? Recreating my local outlook profile?
I think I need more that a walkthrough. Now seriously, in simple words, what does this recreating mean?
Thanks!
