Prospective
- Sep 25, 2014
Hi guys!
I'm looking for new headphones. One for work and the other for home, so I actually get to buy two. I've been thinking about Superluxes. Mainly HD-681 EVO, HD-668b and HD-330. Out of the three I need to choose two.
From what I have gathered it seems that the HD-668B is winner. However I'm little bit concerned are they comfortable to use for long periods. I know that I should at least buy velour pads, but that headband does not look nice at all.
I am going to use the headphones for listening music and watching movies from a laptop. Occasionally I might plug the headphones to my mobile phone too, but that is only when I'm at home or at work. So the use is indoors only.
So which ones would you recommend? Some say the HD-330 are great, even better than 668B, while others say they are not.
How do HD-681 EVO and HD-668B compare?
And the other question:
I know that the EVOs will work fine without a dac and amp. Do I need a dac+amp for HD-668B?
I have narrowed down my choises to FIIO e07k and e10k. I haven't found any comparisons which one is better. Which one would you recommend? Or do I even need it? Are there any others with similar price (60-70€)
And lastly about the velour pads:
It seems that superlux makes velour pads too: http://www.thomann.de/gb/superlux_hd_681_velour_ear_pad.htm
Are they worth it or should I go with something else?
http://www.ebay.com/itm/251636109447?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Were recommended at overclock.net
I am not going to buy the AKG velour pads, because the price is simply too high.
TL; DR;
Which one from superlux:
1. HD-681 EVO
2. HD-668B
3. HD-330
Which dac+amp
1. FIIO e07k
2. FIIO e10k
Budget for headphones ~50€
Budget for dac+amp sub 100€
Thanks in advance!
TL; DR;
1. HD-681 EVO
2. HD-668B
3. HD-330
Which dac+amp
1. FIIO e07k
2. FIIO e10k
Thanks in advance!
