poo
- Apr 9, 2007
Wasn't sure where to put this... but here seems most appropriate
I spent last night drinking Scotch & listening to music. Put simply, it was good.
I am fortunate (and financially deficient) enough to have a few music systems. Every now and then my brain decides to kick into gear, and I realise there is something I can change, modify or do differently within one or more of these systems to get a better result. I use a portable style setup comprising of a Headamp Pico, ALO dock, iPod, and Shure SE530 or Etymotic ER4 IEMs. My primary use of this system is at night when I go to bed so I can listen to music without disturbing my wife. It sounds great, but I realised that for the same price I could probably get a better result.
I use a Benchmark DAC1 USB in my main speaker and headphone systems, controlled by an iPod touch running 'Remote' software (thank god that finally got to see the light of day - and is so damn good!) So last night I had the (somewhat obvious) revelation that I rarely actually use my portable rig outside my damn bed, and never use the DAC in the Pico either... what a waste! It got me thinking that I would be better off selling some of the portable gear and going for more of a 'bedside rig'.
At this stage I plan to purchase a DAC1 (non usb version), into which I will connect an airport express optically (I have one sitting in a box collecting dust). I'll use my iPod touch to control the tunes sent to the express by my server, and continue to use the SE530s and ER4 as IEMs because I need the isolation.
So I guess my reason for posting is to get some feedback on a few areas:
1I have a DAC1 USB and think it sounds great, which is why I plan to buy another (non USB) to use in this new setup. I don't feel the need to use an external headphone amp, the internal unit sounds fine to me. I wonder though, if I might be best to try a different DAC, and if I did, which DAC that might be? I could either go for a comparable DAC with built in headphone amp like a Lavry, or get a cheaper DAC that may not have an internal amp, and pair it with an external amp. Unless the sound quality is noticeably better, I would prefer to stay 'all in one' I guess. Assuming I would be using the Airport Express, the DAC would need to have an optical input. I would like to keep under $1000 USD (a second hand DAC1 is likely to be around $750).
2My understanding of the Airport Express is that it is capable of sending bitperfect audio, limited to 16/44.1 which would be fine for my use in this case. Any reason I should have reservations about using it?
3I presume my IEMs are nowhere near as demanding to drive as my Sennheiser 650s. When using my IEMs, a small change in volume on the DAC1 makes a huge difference. It would be great to change that so the change in volume is not so significant, pretty sure I read once ages ago that there are jumpers within the DAC1 to control this?
4Feel free to point out any shortcomings I may not have considered, or suggest alternative gear.
Thanks for taking the time to help out...
