strangelove
- Feb 9, 2002
Hello all,
I was wondering what solutions exist to add a remote control (wired or wireless) between a source and head amp to adjust volume? It seems odd to me that virtually no heaphone amps (except the Sudgen and Grace as far as I can tell) have the option to have a volume remote. I guess to most people it's a non-issue, but to me the way I listen to music, it's driving me nuts not having a volume control to easily adjust volume. My headphone amp is a good 4-5ft away from my listening position, which requires me to get up everytime I want to change volume. Sometimes there's a loud part to a song/cd that you want to briefly turn the volume down for and the converse for soft passages. Sometimes there might be a song that you just want to "rock out" to and crank the volume up a bit for and then turn it back down after. It gets annoying to keep having to get up (after all, that's why almost all TV's have remotes).
So is there any way to add a source selector/preamp to a set up that allows volume control without significant sound degredation? I looked through old posts but didn't see many options and the ones I did were rather costly. Ideally I'd like to find something in the $100-200 dollar range.
Thanks
Thanks
