Jun 13, 2010 at 11:10 AM Thread Starter Post #1 of 12
Reima
I am looking for a higher capacity battery for my 5.5g 30gb Ipod. It currently has a 540mah battery.
Does anyone have any experience with the following batteries?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390150410103&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300436437716&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370394440128&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190402398634&ssPageName=STRK:MEWAX:IT
I am puzzled as to how come there are 900mah batteries for the 30gb and I can only find 850mah batteries for the 80gb Ipod.
RC
Jun 15, 2010 at 6:36 PM Post #2 of 12
Jun 29, 2010 at 7:29 PM Post #3 of 12
My first test with the 640mah battery yielded an 11% runtime increase over the 540mah battery running ALAC files via Rockbox. 11 hours 30 minutes as opposed to 10 hours 21 minutes.
RC
Jun 29, 2010 at 7:40 PM Post #4 of 12
buy a 32 cf card with adapter, that should increase battery life a lot, make it lighter and increase response. Thought, it seems i'm too late
Jun 29, 2010 at 7:47 PM Post #5 of 12
A 64GB compact flash card is next on my shopping list.
RC
Jun 30, 2010 at 6:55 AM Post #7 of 12
I already have a Tarkan adapter that I will use.
RC
Jul 13, 2010 at 9:26 PM Post #8 of 12
I installed a 64gb cf card, I now get 14 hours and 9 minutes using Rockbox and ALAC.
RC
Jul 13, 2010 at 9:45 PM Post #9 of 12
very nice, I really was expecting more battery life but sounds good nonetheless considering you're only playing lossless.
Jul 16, 2010 at 9:17 AM Post #10 of 12
I think that just sending your imod to RWA is better way. It will get better battery, better parts which are supposed to lack in quality and you could incrase your storage capacity.
Jul 17, 2010 at 8:04 AM Post #11 of 12
RC
What 64gb CF card are you using?  I have Tarkan's adapter in my 32gb 5.5 iMod and Rockboxed and been thinking about going 64.  I've held off since high capacity CF cards can be hit or miss in regards to them being recognized by the firmware.
No troubles?
Jul 17, 2010 at 5:33 PM Post #12 of 12
No troubles?
I am using a Wintec Filemate 600x read, 300x write (model # 3FMCF64GBP-R) that I got from Newegg. It is working just fine so far.
RC
