HelIish
- Sep 28, 2012
I am looking to get a longer power cord for the 2 rear speakers of a 5.1 setup. The speakers are Genelec 6010a's. I can not use an extension as I will be covering the wires with a cable raceway and it will not fit the end piece. The shortest cable I can use is 15ft but would prefer 25ft.
The cables are labeled 10a 125v, on the actual connector that goes into the speaker is says
QUEEN PUO
QP-045
10A 125V-
E183417
I am wondering if I can just use the monoprice cable that fits or the amazon one that fits and is also labeled 10a 125v
http://www.amazon.com/SF-Cable-15ft-1-15P-SPT-2/dp/B009KTDOSC/ref=sr_1_1?s=electronics&ie=UTF8&qid=1354831040&sr=1-1&keywords=10a+125v
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022806&p_id=7674&seq=1&format=1#largeimage
QUEEN PUO
QP-045
10A 125V-
E183417
