ppl
Building amps and assuring water resistance.
- Jun 21, 2001
remember the CMRR is going to fall as the imbalance between the Invert and non invert input resistences. Chances are that thay are not matched. and with a Vol Pot on the Input thay sure will not be.
Ripple current of over 1 Amp for a 4,700uF cap is not crazy. I don't have the Os- con data at hand at the moment HoweverLooking at a CDE type 301 a Low ESR, ESL Fast cap I see a rated Max Ripple Current For a 4,700uF/25 Volt Radial lead Electrolytic is 8.5 Amps @ 120 Hz. and 11.4 @ 20KHz. so ripple current is not a problem in your application. BTW other relavent data for this Capacitor is ESR=0.018 Ohms @ 120Hz. & 0.007 Ohms @ 20KHz. ESL=12 nH.. So at least this cap and probaly the one you use are going to technicaly do the Job.
However I still have a Real problem foating the ground Between two capacitors. However it is your Amp and if you are happy with it that is really all that matters.
