BL33DnEaRs
- Jun 12, 2014
Recently picked up this new DAP. While it sounds good, it drives lower ohm'd iems (16ohm & less) hard, with punchy bass w/o distortion. However, using a higher ohm'd iem, 32 and up, loses all the bass no matter eq setting. Considering looking into amping it. Is the WM port a true LOD like my IPC 7th gen? If so, who makes a decent cable and how does it perform? Shouln't using the WM port negate the dreaded volume cap as well? Thanks in advance.
