List of Headphone Amplifiers with Balance Control (solid state)
May 31, 2021 at 5:26 AM Post #16 of 28
The Cambridge Audio DacMagic Plus has balance control, although hidden. Doesn't even mention it in the manual (You have to be in pre-amp mode, and then hold phase button and turn the volume).
This is a discontinued model.
Aug 3, 2021 at 10:22 PM Post #17 of 28
If anyone has any more listings for solid state headphone amps with balance control but older (and cheaper) I would love to see some.
P.S. Another amp with balance control is Lake People G107.
Nov 13, 2022 at 3:08 PM Post #18 of 28
I was searching for a headphone amp with balance control and came to this thread. I believe the Beresford Capella is not available anymore. I even read that the brand is banned from this site.
Anyway, I found an amp that even has some tone adjustment too: Transrotor Kopfhörerverstärker (translated from German: Transrotor headphone amplifier). I can only find test reports in German, sorry for that. Retail price is € 1.490,-.
The tone adjustment can be switched off. It can be used as a pre amp too. It has two RCA output, one fixed and one variable. In my setup this would be great because I don't have (and am not allowed by the wife) an ideal listing position when playing over the speakers. I'm trying to convince my wife I badly need it :L3000:
Nov 13, 2022 at 3:17 PM Post #19 of 28
Here are four - from Power Holdings:
Lake People G105 MK-II,
Violectric HPA V281,
Violectric HPA V550,
Niimbus US 5.
Nov 13, 2022 at 3:39 PM Post #20 of 28
Thanks for your reaction:
Lake People G105 MK-II will not serve as a preamp for my little Houston mini 1998 tube amp, sadly enough.
The Violectric and the Niimbus would (SPL Phonitor too I guess), but are quite a bit more expensive than the Transrotor. Since the wife don't understand the listening hobby, I already have a hard time convincing her. Another € 500, - or so would make it mission impossible. I was trying to find a decent one for a little bit less, but I don't think there are a lot out there sub € 1.000,-.
May 29, 2023 at 8:27 PM Post #23 of 28
With the contribution of headfiers I'd like to make a permanent and updated list of headphone amps with Balance Control.
The Balance control is a must have feature for the following reasons:
- most of us have a slightly worse hearing in one side (younger the better, just like eyes), image is slightly shifted in comparison to original recording.
- Not every recording is properly balanced, let alone the old ones converted from mono to stereo. The recording equipment up to monitors/headphones or even room used in the pro studio could have had an imbalance in output perception.
- Right/Left drivers have different output due to tolerances in production of each unit (like anything in this world), quality manufacturers could match them up to 0.5db difference, but most of the time is much worst than that.
- Channel imbalance inside the amp, maybe not much of a difference regarding R/L power output, but using a pot the tracking precision is based on volume position which depends on each track recording level and sensivity of each headphone.
Just one of those reasons alone pretend a Balance Control, even more so for amps for traditional speakers which suffer also the reaction of room shape/walls and placement of each speaker respective to listening position.
Instead manufacturers BS told us they remove the Balance Control to have a purest signal path. LOL
They let the signal pass through any kind of component, type of circuit, multiple type of conversions (phono/digital), connectors and jumpers, switchers and relays, even small computers inside... Anything but not a balance control?
It's a desolation to discover that the outcome for now is a little list, I hope to get your contribution to let it grow and push manufacturers to give us THE BALANCE CONTROL!
HEADPHONE AMPLIFIERS WITH BALANCE CONTROL
McIntosh MHA150 € 7.800 / $ 5.000 (DAC ESS9016S, poweramp 2x50Watt 8 Ohm)
Violectric DHA V590 Pro € 3.699 / $$? (DAC AK4490, 256 step)
Violectric DHA V590 € 3.199 / $$? (DAC AK4490)
SPL Phonitor X € 2.399 / $$? (opt. DAC AK4490 Euro 2.799, preamp, ext. remote)
SPL Phonitor XE € 2.099 / $$? (opt. DAC AK4490 Euro 2.799, ext. remote)
RME ADI-2 Pro FS R Black Edition € 1.745 / $$? (DAC AK4493, remote)
RME ADI-2 DAC FS € 990 / $$? (DAC AK4493*, remote) *newer units, old ones AK4490
Nimbus US 4+ € 5.433 / $$?
Luxman P-750u € 4.490 / $ 4.995
Bryston BHA-1 € 3.270 / $$?
Benchmark HPA4 € 3.270 / $ 2.999
Sparkos Labs Aries € 2.999 / $$? (preamp)
Sparkos Labs Aries base € 2.499 / $$?
Lake People Phone-Amp G105 € 389 / $$?
Beresford Capella € 259 / $$?
The following have the BC but it's buried inside menu and not convenient, if a manufacturers want to be included in the upper list they should fix its position with a firmware upgrade (i.e. first of the list pressing "menu").
T+A HA200 € 6.800 / $$? (Balance control inside menu = not convenient; DAC, NO ANALOGUE OUTPUT)
Mytek Brooklyn Bridge € 2.995 / $$? (Balance control inside menu = not convenient, DAC)
Mytek Brooklyn DAC+ € 2.195 / $$? (Balance control inside menu = not convenient, DAC)
Sony TA-ZH1ES € 2.199 / $$? (Balance control inside menu = not convenient, DAC)
Audiolab M-DAC+ € 1.299 / $$? (Balance control inside menu = not convenient, DAC)
NOTES: I'd like to keep the list updated with unit in current production and delete discontinued ones (like Violectric 281).
I'll later add a few features for each unit just for reference, not a features list which is too complicated to maintain.
Price reference is in Euro at the time of update, suggest me the US dollar price so we can keep a list with reference for both Europe and USA at least.
The list started by me searching a solid state device, I've not searched tube amps to avoid nightmares and paranoic years of tube rollin'.
Burson Soloist 3x GT also has balance control
May 29, 2023 at 11:52 PM Post #24 of 28
Violectric HPA V281 has balance control.
Jun 28, 2023 at 7:08 PM Post #26 of 28
Burson Soloist 3x GT has a balance control but only to the pre amp outputs.I use an adapter to connect my headphone cable to the XLR pre amp outputs.
Dec 1, 2024 at 4:47 AM Post #28 of 28
Hi guys,
It's a pretty old topic, but at the moment I am also interested in an amp with balance control.
There's not too many on the market beyond the ones you have mentioned before. I have bought an xDuoo MT-604, it's a dual mono configuration. Not a bad amp, but I am looking for something more serious, probably up to ~2000$.
Any new recommendations?
