Linux users unite!
Nov 2, 2013 at 1:08 AM Post #286 of 501
  I use the exact same decal on my Koss Red Devil ortho mod custom badges. Excellent find, that is a sign it is top notch, I mean the OS not the headphones, I already know they kick everythings butt..
Go FreeBSD or go home. Someone should consolidate my posts into one thing, I can't edit posts.
Nov 2, 2013 at 1:34 AM Post #290 of 501
  What do you hate about it?
1. Obviously Berkeley University and the other arse hats that were involved in the development of Unix have no idea what usability is, I mean imagine using Mac OS X or MS Windows completely relied and based on commands, not a single GUI application to be seen. This includes the web browser.
2. It's a make or break type of OS, if you enter a command especially with port installations and something breaks, be sure to have a snapshot of the virtual machine or backup of the OS to revert to an earlier state, hence either commands make the particular functions work or break the whole thing together.
3. No add/remove program to be seen such as simple uninstallers and delete function in Mac OS X and Windows should a program installation stuff up. If you install a port with a given option to choose extra settings, make config extension sometimes doesn't even work, if you install a port that installs into the same directory as another port particularly a deprecated program or plugin, deinstalling it doesn't work and it will tell you to go erase those installation files one by one, this leads to another problem as you need to change directories for each files location that you want to modify.
4. Obviously not user friendly, which is why most companies use the GUI version of Red Hat linux.
Nov 2, 2013 at 5:35 AM Post #293 of 501
  Great! November is the perfect time to harvest food, football and more knowledge. Will start skimming reading up on FreeBSD this month. The perfect complement to Egg Nog & Sweet Potato Pie!
I got as far as "BSD and Linux devs get on so badly neither is willing to write drivers for the other's filesystems" and stopped - all my data is on ext4, there is no way to read it let alone save anything under BSD (or at least this was the case a couple of months back).  They have fuse-ntfs to read/write to NTFS though, so if you're coming from Windows this might not be a deal breaker.
DefQon outlines plenty of things that it doesn't do well too - really doesn't sound a good choice for a newbie.  Interesting "sales pitch" though, I have to respect the honesty!
Anyway I prefer the cold, like this guy
Nov 2, 2013 at 5:47 AM Post #294 of 501
When in doubt, do the Penguin.
Nov 2, 2013 at 9:58 AM Post #296 of 501
Oh no.
A catalyst update broke my system. Can only login in Failsafe mode.
Nov 2, 2013 at 10:46 AM Post #299 of 501
Can't you just revert to the old one, whether through package management or manually?
I'd done a full system upgrade, so dependencies can be an issue. If I try to downgrade catalyst, I'll have to downgrade Xorg, and the Linux kernel as well.
So its a bit of a long process, I'll do it if there's no other option left, but I've posted on the Archlinux forum, maybe there's some solution.
Its working somewhat alright in Failsafe, just that there are no fancy window effects in KDE.
Nov 2, 2013 at 12:51 PM Post #300 of 501
UPDATE:
Great Success!
I saw that I had enabled the wrong repository by mistake.
It had installed a beta driver, which obviously wasn't ready yet. A change in the repo name, a few package downgrades and finally the problem is solved.
