Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
I know that minimum phase EQ is recommended for correcting frequency response (since frequency response distortions are often themselves minimum phase in the first place, correcting with a minimum phase filter often also corrects the phase response), but what about an EQ setting that you know full well isn't a correction? For some songs I want a really strong bass boost. I found this "bug" in Poweramp for Android where if you lowered many of the sliders in its EQ (as you might when doing subtractive EQing) you get more and more subbass bass boost--and this was a very tight boost, like a kick in your skull.
Now I've EQed all my songs on my phone for correct response with my Philips SHE3580 using foobar2000 and Electri-Q on my computer and the "subbass" EQ setting on Poweramp doesn't work anymore (since there's nothing to correct, I'd have to just lower ALL the sliders, but that somehow changes the frequency response too much). I tried different parametric EQ settings on Electri-Q on my computer and on Neutron amp on Android but nothing seems to quite provide the tight kick that bugged Poweramp EQ provided. I could dial the bass quantity up and up but whereas I got this kick in my head with bugged Poweramp, I get this drawn out rumble, like distant thunder, with Neutron for example. I'm theorizing here that:
1. "Bugged" Poweramp is bugged because it somehow doesn't EQ the lowest frequencies, so when you lower many sliders, the lowest frequencies get boosted relative to the rest of the spectrum. (I could for example dial in much the same setting with the sliders higher up the scale and the subbass seems weaker.)
2. Poweramp may be using a linear phase EQ while I know that Electri-Q is minimum phase, and Neutron may also be minimum phase?
Anyway, intuitively it seems that after I'd corrected the frequency and phase response with a minimum phase filter (Electri-Q), boosting the bass artificially with a minimum phase filter would skew the phase response more and more as I boost the bass, but would this be audible? Whilst if boosting with a linear phase filter, the bass hump should remain centred in the attack although there may be ringing before and after, which may or may not be audible.
Anyway I've reached the end of my knowledge here. Any help from the experts here?
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
