phil2dot6
- Nov 10, 2003
I've just recently bought a Chaintech AV710 from eBay for $25, but after 30 days from the time I purchased the item, the line in burnt out. Here's the story... Since my speakers were plugged into my soundcard, and I didn't want to use the speaker's line out to plug in my headphones, I took out the speaker cables from the AV710's. I then plugged in my newly bought Shure E2C's to test them out. After a few more minutes, I unplugged the canal-phones and plugged back in the speakers, however, the right channel wasn't working. I then made sure that it wasn't just my speakers, and plugged back in the Shures to check the right channel. After plugging them in, everything then was muted. I checked to make sure it wasn't my computer's fault; it turned out that it was the sound card's fault.
I then uninstalled the Envy drivers and plugged my soundcard into a different PCI slot. Installed the drivers again, and nothing worked still. I then uninstalled the drivers and plugged the AV710's in the original slot and installed the drivers once again. No luck. I took out the soundcard and flipped on my onboard sound to make sure my equipment didn't die on me. Thank goodness my headphones and speakers were still operational. However, now, I have a soundcard with a bad line out. I emailed Chaintech about this five days ago, and they gave me a reply:
"Make sure that you plugged in your speakers to the green jack."
So now, how do I work out the warranty details? Their site doesn't specify, nor give any addresses as to where I should send out my bad soundcard for repairs or a replacement. Please help me out!
