Unless they ship it as a gift which I doubt they’d do since it’s a criminal offence - as I said before I’m going to have to pay an unreasonably high rate on it to ship it to the UK (customs duty, import duty... ) so that’s why I didn’t bother reading the full description - because it’s just irrelevant either way. If there’s a British seller that does this specific modification though then I’d be interested.
Either way, I've checked out a couple reviews online and it seems like you still need a pretty strong amp/dac to power even the modded t50rp's to a good volume, especially for quiet music. So even if I wanted to pay the 20% or whatever it was on top of shipping and probably some other fees, idk if it's worth.
There's a sale for the HE400i in the UK. Helps you avoid customs fees which are ridiculous there...
For the DAC/Amp, you can buy straight from Schiit distributor in the UK.
Regarding the issue with the connector, I believe that was with the old HE400i connector. They switched to 2.5mm a while back I believe so it shouldn't have the same issue.
Oh , right I wasn't aware of that, that changes things completely! I'll most likely be getting those then, thanks for informing me . For the dac/amp, you think the fulla 2 is best then?
