rarewolf
The Dioko is definitely the dark horse of the lot. It’s definitely not the most enjoyable nor immersive but without EQ, it sounds the most life-like to me.
Very much like a Planar Chu or 7hz Zero.
Edit: I never really achieved a persistent seal with the S/Z 12 with either the supplied tips nor the Moondrop spring tips. Until I came across my current cable and CP100S tips which has simply been a joy.
Today’s conversation here (a huge part of why I enjoy discussions here) sparked my curiosity so I once again borrowed my daughter’s Diokos and threw on these accessories.
Qudelix on balanced, an effortless perfect seal, zero EQ the Diokos has been a joy to listen to across the genres. That stock bass cut @200hz, gentle pinna gain and extended air frequencies make for lovely extended listening.
While it difficult to know why, I found that the Spring tips are not very good for isolating from the outside. I noticed this right away by trying them with the tv on normal loudness. Once I had well-isolating tips on, the tv goes away and the sub-bass is up 4db. I like the Spinfit CP145s for isolation and comfort, and also find that its “tilting” bore length also mitigates the upper midrange without attenuating the air region. I also cannot agree with modding (IMO) not affecting the technicalities, so I avoid modding until I’ve tried tip rolling… and if tips cannot fix whatever, I consider anything else beating the dead horse… #jussayin
