OogeleyBoogeley
- Feb 10, 2003
hey all,
i finished my meta42 last week and it sounds great!!! the only thing is that the volume output is very weak. when i use my slimx with it (vol 40) the loudest the amp will ever get is the output on the cdp. the way i found this is by plugging in the amp, then the cdp and comparing. i have the amp plugged into my cd deck, the volume is more than adequate. is it the slimx or a possible problem with the amp?
also- the blue LED im using is incredibly bright. its a 5A led, and since im using 2x 9v, so using ohms law i got a 3.2 ohm resistor. i did that, and its still incredibly bright. any ideas on how i can fix that?
thanks in advance,
dan
thanks in advance,
dan
