Laptop power supplies are regulated but switchers. They are relatively noisey and definitely not good for audio. Because a Pimeta has a ground channel it will hide much noise but it is still not a good option.
However, it could be implemented better by simply following the switcing supply with a linear regulator. The switching supply has fair output capacitance already so if you took a 01.uF cermaic cap across the output, followed by an LM317 and a 10uf Tan or 100uF 'lytic cap, that should be sufficient. I left out the description of the LM317 adjustment circuit, if that is more complex than you want to do it then you could just use an LM7815, since most laptop supplies are in the 18V neighborhood (the one linked on ebay is odd, probably old, you'd do better to get an 18V version).
However, typically switching supplies are used for their greater efficiency. A Pimeta only uses ~120mA at most, there is no real benefit to using a switcher on a Pimeta, only more issues to deal with.
