I am really sorry if this has been sorted out before, I could not find any definitive answers though. I have a pair of LCD-2C's which "require" above 100mW of power. Now I don't have a dedicated amplifier just yet, but will be getting one closer to christmas. Can I safely use my onboard soundcard with an integrated amplifier (TI NE5532) for the LCD's. I have no idea of what kind of output power the TI NE5532 is capable of, but the manual for my motherboard states up to 600Ohms.
I've been careful with the volume as I'd only reach as far as about 20% in Windows. It sounds good and all, except theres not much bass.
I've never heard headphones clipping or distort before. Is it easy enough to destinguish, like underpowered speakers? I can however hear, in lack of better knowledge some kind of noise in some tracks. They're however in the same spot of the song everytime. Are these the headphones or just crap in the songs?
Hi
@thegen,
No problem, happy to help.
The honest answer is a definite
NO for using that sound card to drive the LCD 2C from a sonics point of view.
From a technical point of view, in general, most onboard soundcards could
'technically' drive the LCD 2C but it
most definitely won't sound good.
Not to mention the noise floor (SNR & THD), among other things would be terrible as there is also bleed & interference from your PC components.
This is more than likely what you're hearing in some tracks by the noise you describe.
Though I am curious, what song are you listening to which has this particularly?
How well recorded are your music, is it CD Quality, at least 320 kpbs (.mp3), or average 16 bit (.flac / .ogg)?
A headphone amplifier alone won't make your LCD 2C sound better if you don't use something other than the onboard sound.
I suggest also looking into a good DAC, usually an audio interface is the more affordable option compared to most consumer DACs as they last longer & if necessary, you can also use record sound if you feel so inclined.
Some I recommend considering are as follows :
Lexicon Alpha (Have this for almost 20 years, still going strong)
Any Focusrite Scarlett Series.
Try any of the above I mentioned, I am certain you will notice a definite improvement in sound quality.
Depending on how your experience with the audio interfaces go, I also suggest looking into the
Presonus HP4 as a dedicated head amp to start.
By the way, any pro shop will also offer good deals on these pro audio gear as well so it never hurts to ask.
With an interface or DAC in general, you can safely set PC system volume to a 100 % & control overall volume level by program &/or via interface.
You will definitely know if a headphone clips or distorts as there will be all sorts of terrible noise & this definitely isn't good for your ears or your headphone.
Generally, underpowered speakers don't clip or disort per say, they just don't sound like much at all.
Speakers only clip or distort if you run them above spec, say 2000 watts into 4 Ohms which will destroy said speakers in short order.
This also proves why Power & Wattage isn't everything & Current has more to do with how headphones or speakers can sound overall, which is why impedence is also important to a certain extent as it is the resistance on how much electrical signal gear can handle.
For example, think of electricity like water as they act essentially the same by choosing the path of least resistance.
As such, Impedence is like turning a water tap or how open a dam sluice is.
The more flow or electrical current running through gear will influence how much is needed to run said gear to a safe, listening level.
That is, unless you want to lose your hearing in short order.
Unfortnately, I don't have time to go into this now but hopefully I have given you a better idea of what is required.
Hope this all makes sense.
Feel free to ask more.
Hope you have a great day !
