I've made moves to build the the 6336 / 6528 OTL, it's happening and it's going to be a beast.
Given the power tubes require twice the heater and bias current, two of the mains transformers used in the Airmid are needed, one for each channel. The B+ regulators will be dissipating around 12W each, so they will be mounted on a 200mm x 80mm x 40mm heat sink on the rear panel.
The real challenge comes with the increased bias current and power dissipated in the output tube loads. With the sections paralleled, each 6336 / 6528 will be biased at 300mA, as such the load for each tube will need to dissipate around 34W as they will be dropping roughly half the B+ voltage...LOL.
How to get that done? Big ass heat sinks. Going to put big finned heat sinks on the sides of the chassis, 300mm x 80mm x 40mm, courtesy of the diyAudio store.
At 300mA bias, each power tube will be dissipating 24-30W. They will get hot as hell, so I am going to actively cool them. I already have a 5V regulated supply powering the time delay circuitry, I am going to beef up the LDO regulator in that position for higher current and add 3-pin fan headers to the PCB. Will then run a pair of 80mm Noctua NF-A8 5V fans with intake directly below the power tubes.
Output caps are going to be 600uF 450V ClarityCap TC2. They are huge caps, 77mm diameter by 145mm length. Don't have a pic, but will look something like the middle cap below.
I have a general idea of the layout, but need to get the parts in, take some measurements before I can finalize. No prototype, just going to build it.
