*THIS AMPLIFIER IS NO LONGER FOR SALE, sorry :/
The time has come to release my OTL amplifier.
I wanted to name the amplifier after something of personal significance, given the time in my life when this amplifier was developed, it will be called the Airmid after the Gaelic goddess of healing and resurrection.
The price is $2,600 USD.
Here is a photo of the amplifier with the stock tubes, however feet have been added in the final build. I will post additional photos when the amplifier is back from its tour.
Here is a list of the main features of the amp:
There is a forthcoming review from @Monsterzero . @zach915m and the peeps at ZMF also spent time with the amplifier, so he may share some thoughts as well.
- Pair 6J5 / 6C5 input tubes – equivalents like 7A4 can be used with adapters
- Pair of 6AS7G / 6080 / 5998 / 421A / 7236 / 7802 output tubes
- Stock tubes are Russian 6S2S (6J5 equivalent) and 6H13C (6AS7G equivalent) – there will be a discount if the buyer does not want stock tubes included
- HEXFRED diode rectified dual mono power supply
- 30-second built-in time delay and soft start, allowing all tube heaters to fully warm before application of B+
- Separate high-voltage super regulators for each channel, the topology of which was first shared with me by @A2029 of 1101 Audio. I credit him with launching my own interest and exploration of voltage regulator design which will be prominently featured in my work going forward. Please check out 1101 Audio’s excellent amplifier line as well
- Active loading of both 6J5 inputs and 6AS7G outputs for highest detail retrieval, lowest distortion and noise
- Signal path free of electrolytic capacitors for the highest degree of clarity and transparency
- Large ClarityCap film output capacitors allowing for use of low impedance headphones with good low-frequency extension
- 50ohm output impedance with 6AS7G / 6080; 30ohm output impedance with 5998 / 421A
- Powder-coated or anodized aluminum chassis courtesy of Landfall Systems
