vvilliamm
- Oct 5, 2010
MY receiver has changed to the VSX-80TX Elite pair with a sound card on my comp
Wires..
3 x 15ft Premium 3.5mm Stereo Male to 2RCA Male 22AWG Cable (Gold Plated) - Black
http://www.monoprice.com/products/p...=10218&cs_id=1021815&p_id=5600&seq=1&format=2
each wire will be from my sound card to receiver
Front > splits l, r
Center/sub > splits center , sub?
Side > splits l,r
or should i get a shorter adapter.. 7 inch? then buy longer rca cables? to connect to that will there be any loss in quality?
7inch Premium 3.5mm Stereo Male to 2RCA Female 22AWG Cable (Gold Plated) - Black
http://www.monoprice.com/products/p...=10218&cs_id=1021815&p_id=5611&seq=1&format=2
Speaker cable wiring
I dont know which one is the best? so the cl2 ones right? now.. im running about probably 10ft, 10ft, 10ft, 10ft, 10 ft to the receiver. Since its in my room and all ym speakers will be basically facing me.. excpt the side ones are to my sides by 4-5 feet
16 gauge is standard.. or should i go for the lower gauges?
http://www.monoprice.com/products/search.asp?spcDB=10239&spcWord=Speaker+Wires&keyword=speaker wire
Coax Subwoofer cable.
http://www.monoprice.com/products/p...=10236&cs_id=1023603&p_id=2682&seq=1&format=2
Banana Plugs
http://www.monoprice.com/products/subdepartment.asp?c_id=104&cp_id=10401&cs_id=1040115
TOSLINK sound card to receiver
http://www.monoprice.com/products/p...=10229&cs_id=1022904&p_id=6271&seq=1&format=2
now.. which ones to use?
open or closed
Wires..
Front > splits l, r
Side > splits l,r
Banana Plugs
open or closed
