Originally Posted by APWiseman /img/forum/go_quote.gif
What stone do you use to sharpen knives, and what angle do you recommend I hold the knife at? Thanks.
I have a bunch of different stones. Some diamond, but mostly Japanese waterstones, natural and artificial. I mostly use the diamond ones for my lesser knives (diamond is fast-cutting), and the waterstones in a 800-1200-2000-6000/8000 grit sequence, starting later in that sequence, the less work the knife needs.
If I had to be reduced to only two grits, I'd choosee one 800-grit stone, and one 2000-grit stone. I'm not sure what brands, because there has been a lot of activity in the artifical waterstone business lately, and I'm not fully up to date. Possibly Bester for the 800 grit (I have a 1200 grit Bester that is remarkably fast-cutting, though it does require soaking), and maybe a Shapton Glass Stone for the 2000. But that's really going out on a limb for the moment, because I've never tried the Shapton. I do, however, have a couple of them coming this week.
As for angle, I don't know. I don't sit there with a protractor. I sharpen where the edge is, and I do that by:
eye: you can see, as you tilt the blade, when you're not at the edge and need to tilt further.
feel: you can tell when you've gone too far with angle, and, eventually, you get to be able to tell when you're right on the edge
ear: the sounds are very instructive for telling you whether you're on the edge
I hold most knives, and all cleavers by the (back of) the blade to sharpen, though that is not practical for narrow blades like paring knives. That gives more control.
